FCP7 rectangular blips, flashes of green in Sequence none in footage
Russ Nelson
on Dec 7, 2014 at 7:48:01 pm
I'm getting rectangular blips, and flashes of green or partial frames of green in my Sequence. I've tossed render files, I've made the footage off-line and reconnected the footage... no luck.
I imported footage using log & transfer as QT movies. Footage looks good in Viewer (I've also watched footage separately in QT player, and in camera - no problems). I'm getting rectangular blips and green partial or full frames in the sequence and exports.
machine: (OS 10.9.5) iMac 3.06 GHz Intel Core 2 Duo; Ram maxed, NVIDIA GeForce 8800 GS 512 MB
Finished a different project with exact same setting 3 days ago and it's fine.
Russ Nelson
Re: FCP7 rectangular blips, flashes of green in Sequence none in footage
on Dec 8, 2014 at 7:45:16 pm
Found my problem - I recently updated to Motion 5.
It does not play well with FCP7 if they're both on the same drive...
http://support.apple.com/en-us/HT202240
It is strongly recommended that you install Final Cut Pro X, Motion 5, and Compressor 4 on a startup disk that does not have Final Cut Studio (2009) already installed.
