Exporting HDV Footage
Solomon Luzinda
on Nov 14, 2014 at 3:00:26 pm
Hello Guys
I shot some footage using a HDR Sony FX 1000E and captured with the following settings are as follows
Sequence present HDV 1080i50
Capture present HDV Apple ProRes 422
Device Control Sony HDV Firewire.
I have worked with HDV before and there is a flicker on moving images especially with these settings how should i export my sequence to avoid the flickering are there any other settings i should make or should i export as is.
Mark Suszko
Re: Exporting HDV Footage
on Nov 14, 2014 at 7:43:45 pm
Flicker... sounds like maybe you have field order reversed; look at your setting for field order.
