If I'm cropping and zooming in a lot, should I transfer files as Pro Res HQ?
Noam Osband
on Oct 31, 2014 at 3:45:11 pm
I'm working on a project and all the files I ingested are Pro Res (just plain pro res. neither HQ nor proxy). That said, I'm doing a lot of cropping and zooming in. Will everything look better when i zoom in if the footage is Pro Res HQ? I know normally it makes no difference. But I'm wondering if the cropping and zooming changes the answer here.
Mark Suszko
Re: If I'm cropping and zooming in a lot, should I transfer files as Pro Res HQ?
on Nov 5, 2014 at 4:30:44 pm
The improvement between Pro Res 422 and prores HQ is small, but you'll be using up way more drive space for the larger file sizes.
