Converting MTS files to Final Cut compatible MP4 files
Grai Rice
on Oct 18, 2014 at 10:36:51 pm
I recently used a camera for a shoot that has created digital files in MTS format. Final Cut does not recognize these files. How can I convert MTS to MP4?
Thank you
Shane Ross
Re: Converting MTS files to Final Cut compatible MP4 files
on Oct 21, 2014 at 4:25:39 am
MP4 isn't a Final Cut compatible codec. ProRes is.
Typically you would use Log and Transfer to bring in this footage. Here's a tutorial on how to do that.
However, some newer cameras aren't compatible with FCP 7...they might shoot a format it doesn't work with, like 1080p60. For that, you need ClipWrap2 from divergentmedia.com. And convert to ProRes 422.
Shane
Little Frog Post
