Apply blending to specific layers.
Adam Hutchison
on Oct 6, 2014 at 3:55:06 pm
Hi there.
I've tried searching everywhere, but I can't find an answer for this within FCP.
I'm trying to blend some burn stock with a text layer using the 'darken' blend mode, but I want the bottom layer to be unaffected by the blend. Is this possible?
I know there are other, lengthier ways around this, but I would just like to know if you are able to select which specific layers can be blended, and whether you can exclude layers.
Many thanks.
Mark Suszko
Re: Apply blending to specific layers.
on Oct 7, 2014 at 3:02:17 pm
I think the blend by nature affects all layers below it. What you might try is luma keying or revering the key.
