How to create a duplicate project file in FCP 6 and convert to FCP 7
Tamera Coleman
on Sep 9, 2014 at 4:30:46 am
Hello, I am trying to convert a FCP 6 project > FCP 7. I was given seemingly easy instructions (1) create a FCP 7 folder on the external HD (2) duplicate the project file (3) copy it to the FCP 7 folder (4) open FCP 7 application then open the duplicate version of the project file that was saved to the new FCP 7 folder.
My question: Is there a 'visual/tutorial' available, so I can identify the project file? What should the project file look like?
Also, I read a post that suggested using media manager and copying everything over {rendered files, etc]. Thanks.
Daniel Sametz
Re: How to create a duplicate project file in FCP 6 and convert to FCP 7
on Sep 9, 2014 at 5:44:38 am
It will look like this.
Move you old project, render files, capture scratch, auto save files, etc to a external HDD (Because you should always edit in an external HDD), then duplicate your old project file (like the one on the picture) so you´ll leave your original safe and open it on Final 7.It will ask you if you want to convert it to final 7 or something like that, say yes and there you are.
Good luck :)
Tamera Coleman
on Sep 9, 2014 at 4:07:30 pm
Thanks. But want to clarify. You're suggesting I "move" the project file. Shouldn't the file(s) be copied to the external HD, not "moved"?
Daniel Sametz
on Sep 23, 2014 at 9:37:17 pm
Sorry for the delay.
So If move your project file it does´t matter as long as what you open is your duplicate and not the original. Keep a copy of what you are moving in it´s original place but make sure you change the project settings to your new place.
