PAL recorded material into NTSC DVD
Jimena Mora
on Aug 2, 2014 at 3:56:41 pm
Hello
I have a question about how to make a high quality DVD from FCP7 that can read by any DVD player, PC computer or MAC. It will be projected in a big screen.
My sequence settings are:
Frame Size 1920 x 1080 HDTV 1080i (16:9)
Quick Time video settings: Apple ProRes 422 HQ
Pixel Aspect Ratio: Square
Do I have to take it to Compressor and then DVD Studio Pro or directly to DVD studio Pro? Im not sure how to set the settings to export this video.
Thanks in advance,
Jimena
John Fishback
Re: PAL recorded material into NTSC DVD
on Aug 11, 2014 at 3:13:08 pm
I always export a master clip at current settings, then use that clip in Compressor. There is no DVD that will play in all the standards, although, many PAL players will play NTSC DVDs. If your DVD is for a critical use, be sure to test the DVD in the player that will be used.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.9.2, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCP-X 10.1.1, Motion 5.0.7, Compressor 4.0.7
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
