Newbie needs workflow for AVCHD files with Separate Audio in FCP7
Josh Daniels
on Apr 17, 2014 at 7:26:58 pm
I've been struggling for a few days with this and I'm pretty sure that my receding hairline has receded even more as a result.
I have a 4 camera project - a concert with approximately 1 hour of continuous shooting for each camera. The audio is a separate mix of the show.
The cameras are mt2s at 59.94 fps with audio at 44.1. The separate mix is is 44.1 as well. I would like to sync all 4 cameras with the audio and make a multiclip of the show. What would be a smart way to go about this?
Josh
Shane Ross
Re: Newbie needs workflow for AVCHD files with Separate Audio in FCP7
on Apr 17, 2014 at 7:44:00 pm
First off, convert all the audio to 48Khz. FCP doesn't sync properly with 44.1Khz. Not sure how a camera comes to record audio at 44.1K...all the ones I know record at 48K.
Shane
Little Frog Post
Josh Daniels
on Apr 18, 2014 at 4:08:42 pm
Thanks - yes, you are correct. The original MT2Ss have 48K. I asked for a 48K WAV mixdown of the audio track and got one. I tried to convert to the Intermediate Codec and sync via in-points.
I can get sync on all of the video in a multiclip, but the audio track is way way off - by minutes, even when I select the same in point.
