 | Can't set Capture and Scratch disk
on Jan 27, 2014 at 5:58:41 pm |
Hi All,
I am not a regular FCP user. My editor is working with FCP 7 and in order to prepare for him, I am also working with 7. I recently had to have FCP7 re installed. Now when I try to start up, instead of getting the message to choose where to set capture and scratch disk, as i want to assign this to an external drive, I get External A/V pop up and it just says that it is unable to locate the drive and then says your system configuration may have changed....etc....
I believe this must have been changed when the tech re installed ..but i don't know how to change it back....
if i just hit continue i get an error saying that my disk is almost full and i need to free up space
can anyone tell me how to get this re set?...
thanks...k
 | Re: Can't set Capture and Scratch disk on Feb 4, 2014 at 6:09:05 pm |
Go into Capture Settings and reset all of the settings to a source drive with space available. I believe it also gives you that option when you get the original error message you entered?
