View actual clip audio levels in timeline FCP 7
Angela Anderson
on Nov 4, 2013 at 1:22:06 pm
Hi there creative cow lovelies,
I have a question which is killing me trying to solve, because like it seems like it should be obvious but I can't figure it out. I'm about to embark on a sound mix in fcp - is there any way to see the levels of the clips in the timeline in numerical form somewhere? like if i put the playhead on a particular place in the clip, is there some way I can see what the audio level is set at, numerically?
Thank you very much anyone who might know!
John Fishback
Re: View actual clip audio levels in timeline FCP 7
on Nov 4, 2013 at 5:26:15 pm
If you don't see the vertical audio meters, hit Opt-4 to reveal them. In the timeline, if you have Clip Overlays (Opt-W) on you will see a line in each clip representing the gain setting applied. If you click on that line and slightly move the mouse up or down you will see the gain level (odb, -3db, etc.) However, only the audio meters will show you the actual level. One nice feature is you can see level indications as you scrub through a clip. It's a nice way to identify hits in the audio that might clip.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
