Final Cut Pro 7 project saved as an Executable UNIX file ?!? WTF ?!?
Benoit Moget
on Sep 27, 2013 at 10:50:20 am
Hello!
I'm getting crazy because as I'm doing my Final cut project, I naturally save it regularly not to lose everything, right ?! But when I wanted to go back on it the next day, I see that the project was saved under "Executable UNIX file" (which only execution is to make me crazy) instead of a normal Final Cut file.
Does anyone know why it does that? and how can I switch that saving process back to normal please???
ps: I use Final Cut Pro 7.03 on Mac OS X 10.8.5
Rafael Amador
Re: Final Cut Pro 7 project saved as an Executable UNIX file ?!? WTF ?!?
on Sep 28, 2013 at 6:37:57 am
That means that your MacOS system needs dome maintenance.
First, re-launch the Finder.
If that doesn't works try repairing Permissions.
If that doesn't works, run DiskWarrior or TechTools.
rafael
Benoit Moget
on Sep 29, 2013 at 8:28:39 am
Actually I was sick of having problems so I bought Final Cut Pro X :) But thank you a bunch for your answer!
