Quicktime 0 error FCPX when trying to burn DVD
Ron Zelt
on Jul 24, 2013 at 3:55:52 pm
Similar to previous posted in June. I have same problem trying to burn a dvd that previously burned without incident. Tried deleting preferences as suggested by someone but no change. Able to burn a 3 min short without a problem. Stops always at 48% when trying to burn a 58 min project. Must be some error embedded in the project as always stops at same place. Any ideas? Thanks!
Mark Suszko
Re: Quicktime 0 error FCPX when trying to burn DVD
on Jul 24, 2013 at 6:06:11 pm
I'm guessing your "c" drive, where the program is compiling, has run low on space. Delete all previous instances and renders from this job, and actually empty the trash. Set the rendering to go to a drive other than your system drive. Then try it again.
