Color Correction doesn't apply
Ana Garcia
on Jun 6, 2013 at 2:38:48 pm
I was trying to color correct a project but the effects doesn't apply to the image. Does anyone know what can be or how to fix it?
Thank you
Mark Suszko
Re: Color Correction doesn't apply
on Jun 6, 2013 at 4:22:18 pm
Double-click the clip to select it, then apply the color correction tools to it.
Ana Garcia
on Jun 6, 2013 at 4:58:52 pm
I've already done that. It still doesn't work :S
Mark Suszko
on Jun 6, 2013 at 8:51:51 pm
Are you dragging an icon onto the clip, or are you going to the top menu after highlightng, and selecting from the drop-downs:
EFFECTS> VIDEO FILTERS> COLOR CORRECTION> your choice
Are you in FCP 7 or are you in X?
Ana Garcia
on Jun 7, 2013 at 9:47:15 am
I'm working in FCP 7 and I've tried both ways, dragging the icon into the clip and the top menu thing.
Whenever I try to intervene, and perform any command in the effect, it doesn't apply.
Rafael Amador
on Jun 7, 2013 at 1:16:38 pm
Double click the clip on the time-line and click the "Effects" tab on the viewer.
Make your changes there.
rafael
Tom Durham
on Jun 7, 2013 at 1:24:39 pm
Hey Rafael! Once upon a time someone made mention of two filters to be applied in FCP to make the project broadcast safe, since the Broadcast Safe filter doesn't do the whole job. Was that you? :) Do you happen to remember which filters they were and what the settings were?
THANKS!
-Tom
YOU can help save TimeSpace. Join the Chronos Protectorate!
http://www.95ers.com
http://www.SpaceAceMedia.com
