chromakey isn't rendering
Andy Pearson
on May 17, 2013 at 10:56:12 am
I am trying to key a JPEG over moving footage in FCP 6.
The JPEG is a packshot with a chromakey green background.
I have set it up in the timeline with a Chromakey filter that is working fine and I can seethe composite image exactly how I want it - the packshot keyed over the background footage.
Chromakey layer is V2 and Footage is V1. I select both then hit Render. But the clip doesn't render it either won't render at all if I lasso the two clips or, if I click-select both clips it processes the render but when it is finished the key hasn't worked.
What am I doing wrong?
Rafael Amador
Re: chromakey isn't rendering
on May 17, 2013 at 2:57:19 pm
If the effect can be played in RT, Cmd-R won't render it.
Try Option-R.
rafael
Mark Suszko
on May 17, 2013 at 3:40:39 pm
Try highlight all related clips, then in the top menus, select Sequence>Render Only>Needs Rendering
