App or plugin for lines removal from damaged sensor
Otto Preminger
on Apr 25, 2013 at 11:15:34 am
Dear all I have a bad luck with my GH2 camera due to the damaged sensor and I need help to chose app that is able to remove one horizontal an two vertical lines that apears acros whole frame.
I have FCP installed on my pc and I am not well experinced so some tutorial will be of great help for me.
Thank you in advance.
5911_p1020810.jpg.zip
Shane Ross
Re: App or plugin for lines removal from damaged sensor
on Apr 25, 2013 at 5:29:02 pm
Oooof! That's a very damaged sensor! I know of tools to remove dead pixels:
http://www.digital-heaven.co.uk/dh_reincarnation
And occasional dropouts:
http://www.digital-heaven.co.uk/dh_dropout
But that is pretty bad.
Shane
Little Frog Post
Otto Preminger
on Apr 25, 2013 at 6:54:51 pm
Thank you for your answer. Does somebody know for some sratch removal softvare?
May be it is possible to remove lines if a sftware threat them as a scrathes?
After googling I have found Pixel farm cleaning app. Is someone experienced with this software?
Thank you all.
Otto Preminger
on May 15, 2013 at 1:51:05 pm
I got some results with PFClean sratch removal but "sratches" occasionally appears after removal.
Is anybody have experience with this proceed?
Thanks.
