matching sequence clips back to their original assembly
Karen Sinclair
on Mar 16, 2013 at 6:11:29 am
i can match frame a sequence clip back to the master clip,
and i can reveal it in a finder window, but is it possible to
match back to the sequence i took the clip from?
or is this something you can only do on an AVID ?
Shane Ross
Re: matching sequence clips back to their original assembly
on Mar 20, 2013 at 7:20:09 pm
"F" is the keyboard command to match frame...load the clip into the Viewer. And then to match to it in a bin, you press SHIFT-F.
To find it in the finder...right click on the clip in the timeline and select REVEAL IN FINDER.
Shane
Little Frog Post
