Rendering all the time
Winter Prince
on Mar 4, 2013 at 1:39:22 pm
Why does my FCP object have to render every time I change something. Even something as simple as a keyframe movement.
Can someone explain or tel me how to make the proper settings change on the FCP7?
Mark Suszko
Re: Rendering all the time
on Mar 4, 2013 at 3:53:11 pm
To get the best advice and help, use the tools just above the comment box to post snapshots of your Sequence settings and the settings for your footage. If your footage is h.264, that's the problem right there: FCP doesn't edit well at all with that and you would need to first transcode it to another format, which is not a hard thing to do.
Rendering "all the time" means to me that your project and sequence settings don't match the footage settings.
