reversing order of a string of photos w/transitions
Craig Johnson
on Feb 15, 2013 at 4:44:41 am
Just like the topic line reads. I have a project with about 45 photos running consecutively with a basic transition between each, at the end of the video, I would like to flip the order with transitions intact. I've tried a few basic things but no joy. Is there such a feature?
Todd Gillespie
Re: reversing order of a string of photos w/transitions
on Feb 15, 2013 at 6:46:36 am
Either render a movie or nest a sequence. Then make a new sequence and reserve the timing. Only way i can think. But the movement will also be in reserve. May not be what you want.
Todd at UCSB
Television Production
Rafael Amador
on Feb 15, 2013 at 1:45:10 pm
..or you can use the free "Reverse" plugin, that basically does the same than what Todd suggested:
http://www.nattress.com/Free/freeFCP.htm
The truth is that Nattress developed this plugin because setting the speed at -100% has a bug in FC, but that's with interlaced stuff, so no your case.
rafael
