New Computer, what am I missing
Louis Stevenson
on Jan 24, 2013 at 9:20:50 pm
I got a new Macbook and am working on putting a new reel together.
The problem I am having with some of the clips is the "General Error Out of Memory," which usually happens with incompatible video formats.
I know these videos should be compatible with FCP, since I made them, and used them, in FCP on my older macbook.
I'm guessing i'm missing some codecs or something, and "Genreal Error" doesn't help me figure out what they could be.
Any suggestions?
The clips are h.264 and I'm using the same version of FCP I used on the original edits, version 7.
Chris Tompkins
Re: New Computer, what am I missing
on Jan 24, 2013 at 9:29:30 pm
u can't edit .h264 file in FCP
Chris
Louis Stevenson
on Jan 24, 2013 at 11:30:58 pm
What codec can i use that will let me?
I've been able to do it before.
Shane Ross
on Jan 24, 2013 at 11:43:00 pm
ProRes. H.264 is unpredictable in FCP. It might work...it might not. And when it doesn't, a variety of things can go wrong...there isn't one set thing that doesn't work. Best to convert to ProRes.
Shane
Little Frog Post
