Annoying problem after splitting a clip with blade tool
Jake Taylor
on Oct 24, 2012 at 4:09:43 pm
I'm just doing some basic editing, nothing fancy whatsoever and I've split up a few sections of video into smaller segments using the blade tool.
Where I run into the problem is when trying to delete one of the segments it will also delete audio for the next segment.
I've tried looking to see if the clip segments are linked, etc, but so far I haven't been able to figure it out or create a work-around to fix the problem. Any help is appreciated, thanks!
Edit: This only happens for ONE segmented part of the clip so far, as an additional note.
Mark Suszko
Re: Annoying problem after splitting a clip with blade tool
on Oct 25, 2012 at 1:54:49 pm
Hit the blade tool key as many times as you have tracks. Then mark your cuts. Are you leaving the tracks highlighted?
