upgraded to mac os 10.8, now audio doesn't work in clipwrap
Ross Lenihan
on Oct 10, 2012 at 5:36:04 pm
i recently upgraded to OS 10.8 and now the audio for my clipwrap-converted MTS files does not work.
i read that perian stopped operating and that this would definitely impact 10.8, so i assumed this was part of the issue.
now when i convert my MTS fils to a format i can use in final cut pro (pro res LT) the audio does not work. and it doesn't matter if i use LPCM sound or not.
any help on this? thank you!
Colin McFadden
Re: upgraded to mac os 10.8, now audio doesn't work in clipwrap
on Oct 11, 2012 at 2:25:19 pm
Hi there - you need to be running at least ClipWrap 2.5.2 on Mountain Lion. It sounds like you've got an older version.
Just download a fresh copy from: http://www.divergentmedia.com/filedownload/clipwrap
-Colin
support@divergentmedia.com
Ross Lenihan
on Oct 11, 2012 at 6:35:43 pm
thanks colin! i think that's the issue. chalk one up to common sense.
