Sequence setting for material shot on Panasonic HVX 150
meghna damani
on Sep 17, 2012 at 5:43:35 pm
I am editing footage shot on Panasonic HVX 150. Dimensions 1920 × 1080, Codecs H.264, Linear PCM, Timecode
What Sequence settings should I use in final cut Version 6.06?
Shane Ross
Re: Sequence setting for material shot on Panasonic HVX 150
on Sep 17, 2012 at 6:08:52 pm
YOu mean HMC-150. That shoots AVCHD. You use LOG AND TRANSFER to bring that footage into FCP...converting it to ProRes 422. You cannot edit that format natively in FCP.
Tutorial:
http://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
(Note, the tutorial is for FCP 7, so you won't have some of the same codec options or renaming options. But the basics are the same)
Shane
Little Frog Post
