moving logos
Robert Schmidtbauer
moving logos
on Jul 12, 2012 at 6:04:34 pm
making psds move, how do I make all the layers move together, when I double click on it final cut gives me a separate timeline? When I use jpeg images it puts a white back ground on them?
Mark Suszko
Re: moving logos
on Jul 12, 2012 at 7:12:36 pm
Did you try a drag and drop instead of a double-click?
Robert Schmidtbauer
Re: moving logos
on Jul 12, 2012 at 7:15:25 pm
thanks that seems to work...
keith mcgregor
Re: moving logos
on Jul 24, 2012 at 4:36:13 pm
When you import PSD to FCP it comes in as a sequence, that's what your "separate timeline' is all about. Jpgs cannot hold a transparency channel (only RGB) so there will be no alpha (RGBA) and it will show either a white or black bkgrnd. You should be using AE for your graphics animation, FCP is clunky.
-Keith
Reality? What did you make it?
