Export by reference
Mike Raff
Export by reference
on Jun 21, 2012 at 10:05:13 pm
I confess, I've never really understood this. I mean, I get the idea: you're exporting pointers to the actual media, not the media itself and that's supposed to result in a much smaller file. But I must not understand how to do it.
For example, I select a sequence and go File>Export>QuickTime Movie and
Setting: Current Settings
Include: Audio and Video
Markers: None
and leave both the Recompress All Frames and Make Movie Self-Contained checkboxes UNCHECKED.
Is that not the correct method?
I've done it that way and also tried it with the Make Movie Self-Contained box checked and both files came out precisely the same size.
What am I missing?
TIA,
Mike Raff
Richmond, VA
Michael Cheung
Re: Export by reference
on Jun 22, 2012 at 7:04:27 am
It's a different type in the export menu. In the drop down list where it's says send to quicktime or something, there should be a quicktime reference movie option.
Michael Cheung
David Eaks
on Jun 22, 2012 at 8:40:43 am
I export reference movies from FCP7 all the time, with regular export (cmd-e) and simply leaving self-contained unchecked. Not sure why it isn't working for you.
I wasn't even aware of any reference movie option under QuickTime Conversion, sure that's not Avids menu you're thinking of?
Michael Cheung
on Jun 22, 2012 at 8:54:29 am
That's exactly what I'm thinking of. Can you tell which I've been using recently!
Rafael Amador
on Jun 22, 2012 at 9:15:00 am
That's the correct method, being the sequence fully rendered.
If is not working, try refreshing FC preferences.
rafael
http://www.nagavideo.com
Kylee Peña
on Jun 22, 2012 at 1:26:08 pm
Is your sequence unrendered?
blog: kyleesportfolio.com/blog
twitter: @kyl33t
demo: kyleewall.com
