How do I increase footage size to fit the screen?
Cilla Ras
on Jun 3, 2012 at 6:58:28 am
Hi there. I went to copy some of my timeline to another sequence but when it displayed in the canvas it was a mini version of what it should be - it did not fit the entire frame. This was the same for all the footage expect a couple of still shots which filled the frame. How do I increase everything so its full frame and will also be full frame when I compress and burn it to DVD?
Thanks so much!
Cilla
Stephen Smith
Re: How do I increase footage size to fit the screen?
on Jun 4, 2012 at 3:12:09 pm
This happens when you copy clips to a different sequence size. You can increase the scale of one clip and then copy it. Then select all of the other clips and right click on one. Choose Paste Attributes and then check the Basic Motion Check box. Best of luck.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
