Sync sound pile of work
Stephen Kuns
on May 20, 2012 at 11:58:11 pm
I have these elements from a two camera shoot. I hand synced all of the A camera using the clapper merge clips. Now the B camera has the same timecode as the A camera. Can I just use the timecode from A to match them up ands create new clips with sync audio? There in no timecode on the sound.
Stephen Kuns
(trying to help someone out)
Stephen Kuns
Colorist
LA CA
Anna Ingenthron
Re: Sync sound pile of work
on Aug 23, 2012 at 6:19:35 am
You can use the timecode and create multiclips, though you may want to manually check the audio sync is still correct. I recommend using Pluraleyes to speed the process up. It's cheap if you want to buy it, but they also have a 30 day trial.
