Batch effects into different files
Eldárwen Lissësúl
on May 8, 2012 at 11:47:30 pm
I have 86 small, separate, video clip files, each lasting 15 seconds. I would like to apply the strobe effect to each of these files so that they all show the same effect. I was wondering if there was a way of doing this as a batch process or if I need to do each file individually.
Rafael Amador
Re: Batch effects into different files
on May 10, 2012 at 2:05:20 am
If you want to keep each ciip as the original (separated) just with the effect added, you need to export the clips one by one.
rafael
http://www.nagavideo.com
