DCP format
Jimena Mora
DCP format
on May 5, 2012 at 11:05:04 am
Hello
I would like to know if it is possible to export a FCP project into DCP format? I think I would need to use other software to make a conversion. Anybody knows what is the best way to do it?
Thanks in advance
Jimena
Andrew Rendell
Re: DCP format
on May 5, 2012 at 1:23:04 pm
FCP doesn't export to DCP.
The subject has come up before though, so I'd recommend you go to the main forums page http://forums.creativecow.net/ and type DCP into the search panel and have a trawl through the responses there.
Jimena Mora
Re: DCP format
on May 5, 2012 at 6:07:15 pm
Thank you Andrew! Do you know which software I could use to convert the FCP project into DCP format?
Andrew Rendell
Re: DCP format
on May 6, 2012 at 10:06:06 am
Take a look at Wraptor, although other software is available. There are variatons in DCP, so have a good read up on it before you proceed.
TBH, it's the kind of thing that I go to a facility to get done as don't do enough to make it worthwhile gearing up for it.
Jimena Mora
Re: DCP format
on May 7, 2012 at 7:58:27 am
Thank you Andrew I will take a look at Wraptor!
Stephen Smith
Re: DCP format
on May 7, 2012 at 3:54:28 pm
I've done DCP files at a local facility that has their own 2K projector so they can verify everything looks right. It is the Color Mill: http://www.colormill.net/
Stephen Smith
Utah Video Productions
Check out my Vimeo page
