Sequence shows as white in Canvas
Terence Lyons
on Apr 25, 2012 at 4:34:41 pm
I have imported QT movie into my project and have dropped it down into the timeline. When I scrub through it, nothing shows in the Canvas though with Audio Scrubbing set to On there is sound. If I play forward by hitting the "L" key, the movie does show in the Canvas. If it makes a difference, View/Video Playback is set to: Digital Cinema Desktop Preview - Main.
What should I do?
Kylee Peña
Re: Sequence shows as white in Canvas
on Apr 25, 2012 at 8:01:10 pm
What is your sequence setting, and the codec of your QT movie?
Terry Lyons
on Apr 25, 2012 at 9:40:29 pm
Kylee,
The properties of the .mov file are: Apple ProRes 422,
Linear PCM, Timecode
1920 x 1080
The sequence settings in FCP are:
Frame Size: 1920 x 1080 HDTV 1080i(16:9)
Pixel Aspect: Square
Quicktime Video Settings/Compressor: Apple ProRes 422
Terence Lyons
web/multimedia/photography
Shane Ross
on Apr 26, 2012 at 2:18:56 pm
#15 White or Black Canvas or Viewer
Shane's Stock Answer #15: White or Black Canvas or Viewer
Make sure the canvas or viewer are selected then go to VIEW>CHANNELS and set it to RGB. It might be set to ALPHA.
OR...
Click on the drop down menu above the Viewer or Canvas and make sure that you are on IMAGE or IMAGE + WIREFRAME.
Shane
Little Frog Post
Terry Lyons
Re: Sequence shows as white in Canvas - Solved!
on Apr 26, 2012 at 3:34:21 pm
Shane,
"VIEW>CHANNELS and set it to RGB" did the trick! Thanks so much!
Now, how would I of had that set like that?
Terence Lyons
Kylee Peña
on Apr 29, 2012 at 11:22:24 pm
You probably accidentally hit a keyboard shortcut. I think that one is shift-W?
