XDcam to DV Pal Field problems
M. Louise May
on Apr 22, 2012 at 8:51:44 pm
Hello!
I'd like to ask for your advice in this subject:
XDcam 1080 50i shot on EX 1, edit in FCP XDCam sequence, export a XDCam HD 422.
I need a SD DV Pal copy of this, so I create a DVPal sequence, lower field first, and drop my XD movie there.
Then I connect to an oooold DSR11 to print to DV tape.
Problems: Field problems on DV sequence . I change from lower to upper field, field problem still there, in computer and also ext monitor.
Any ideas what I'm doing wrong?
Thank you, thank you, thank you!
