FCP 7 & Canon5d Mkiii (new compression format) work flow
Dave Francombe
on Apr 18, 2012 at 4:25:36 pm
Anyone have any suggestions. Log & transfer doesn't recognize the files in either format.
My QT & FCP & timeline doesn't see ALL-I compression in QT10 and compressor won't spit out a pro-res file.
MY QT & FCP 7 timeline will see IPB compression but I prefer to encode to pro res to edit using a Kona card and broadcast monitor. Unfortunately compressor seems to be putting in major artifacts into the transcode.
Any advice on setting etc would be great. Thanks
Neil Patience
Re: FCP 7 & Canon5d Mkiii (new compression format) work flow
on Apr 18, 2012 at 7:19:38 pm
I wonder if the issue not recognising the files will be cured by editing the camera plist file as you have to do for the T2i/550D
Might be worth a go - instructions here
http://www.patience.tv/blog_files/tag-eos-550d-t2i-log-and-transfer-problem...
try adding EOS 5D Mark III to the list ?
Total guess - but might work.
best wishes
Neil
