sequence settings...
julienne rathore
on Apr 18, 2012 at 10:16:45 am
dear creative cow,
a very basic question:
i am editing a montage made up solely of many stills, all png files.
the stills are all originally taken from video files (both apple intermediate codec and apple pro res) - what should my sequence settings be?
thanks in advance!
julienne
Chris Tompkins
Re: sequence settings...
on Apr 18, 2012 at 10:36:15 am
What is your end destination?
If it's DVD (SD) then choose the DV NTSC (if in NTSC land) preset.
Edit video till done and then,
Change the sequence settings to 8 bit uncompressed and re-render fully.
Then Export using Current Settings.
Drop file into compressor to create the DVD files.
Chris Tompkins
Video Atlanta LLC
julienne rathore
on Apr 18, 2012 at 11:33:31 am
end destination is visual projection mix.
Chris Tompkins
on Apr 18, 2012 at 11:46:48 am
So a digital file then? A mov? a WMV? in a powerpoint? mp4?
If your stills are from a video, then those are your specs, IE:720x480
See comments above for spec recommendations.
Chris Tompkins
Video Atlanta LLC
julienne rathore
on Apr 18, 2012 at 12:16:28 pm
Maybe I should have been clearer with my details - sorry!:
the montage contains only stills, all png files.
the stills are all from video files (apple intermediate codec AND apple pro res).
the end destionation is a .mov for visual projection.
i'm not sure if I should set the sequence presets to pro res or apple intermediate (original video is in these 2 formats), or simply hdv?
(the rest is 1920x1080 and I have chosen 50i since both original video formats are 25fps interlaced).
julienne
