new version 10.0.04 and LaCie problems??
Ben Jacob
on Apr 17, 2012 at 6:05:25 pm
I'm running OS lion on iMac and FCPX. My FCP projects are kept on external drives: 2x lacie d2 quadras and a western digital. The lacie drives connect via firewire of usb 3.0; the other, which is really just a backup, via usb 2.0.
Ever since the update to FCPX last Friday, FCP freezes every time I attempt to access the projects on both LaCie drives - it freezes on the project library screen. But, using FCP to access the projects on the western digital external works fine.
I was advised by the apple geniuses to remove the existing preferences files - done; did not fix the freezing - and then to trash and reinstall FCPX from app store - done, problem persists.
Any idea why this has happened or what I can do? Both external drives seem to have no faults, files can be copied/pasted from one to another, but I cannot access the projects through FCP.... Any way around this? Thanks in advance - and has anyone else had this problem since the update?
