re-installing Final Cut Studio 3/Final Cut Pro 7.0.3
John A Spillane
on Apr 16, 2012 at 10:19:16 pm
I'm about to erase and re-format the drive on my iMac that runs my Final Cut Studio 3/Final Cut Pro 7.0.3 application.[ iMac 6.1 IntelCore 2 Duo 2.16GHz 3 GB memory.]
I will use my Final Cut Studio DVDs to re-install. So far so good. But then I need to find software updates for Final Cut Pro and other applications. Are they still available? Thanks, John
Neil Patience
Re: re-installing Final Cut Studio 3/Final Cut Pro 7.0.3
on Apr 18, 2012 at 8:55:05 am
The ProApps updates for FCP7 are indeed still available here
http://support.apple.com/kb/DL949
best wishes
Neil
http://www.patience.tv
John A Spillane
on Apr 18, 2012 at 4:52:05 pm
Neil, Thank you. That was quick. I seem to remember that link vanishing after FinalCutX was introduced. Glad to see it back, if that's what happened. Thanks again, John
Neil Patience
on Apr 18, 2012 at 7:46:44 pm
No Problem - I believe you are correct and they did vanish for a while but then they came back luckily. Not sure how long they will be around for you never can tell with Apple.
best wishes
Neil
