Opening new projects in fcp7
Mike Rasch
on Apr 16, 2012 at 4:41:54 pm
Whenever I open fcp7 it keeps opening the last project I had been working on. I guess it's a default setting that needs to be changed, but I can't figure out how to change it. I would like to open up fcp7 with a new project every time. Any help would be great.
Neil Patience
Re: Opening new projects in fcp7
on Apr 18, 2012 at 9:00:12 am
If you go to User Prefs under the General tab you will see the option for open last project on application launch.
Select or not as required - (just above the autosave vault options)
best wishes
© 2018 All Rights Reserved
