Paths for final cut pro
Eddie Aldridge
on Apr 13, 2012 at 12:33:30 pm
Just started using final cut pro.
Created myself an issue I hope someone can help me with.
I imported the files from my video camera into FCP
I then copied the files also to a specific directory on my system
I then erased the data from the camera and used the card for a new video
Now I deleted the project in FCP after playing around, understanding what I want to do
I now create a new project and click the import section to import the files again from the directory I have stored them in, but the files are all grey'd out, visible but not accessible.
Now I am stuck as I do not know on how to get FCP to import the files so that I can create a new project.
Any help much appreciated
Eddie
Stephen Smith
Re: Paths for final cut pro
on Apr 13, 2012 at 3:01:34 pm
Did you log and transfer the files off the card or just transfer the card to a hard drive and import the files into FCP6?
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Eddie Aldridge
on Apr 13, 2012 at 3:15:58 pm
I have the first time done an import from the camera.
The second instance I just copied all the files from the card via a card reader into a directory I created.
Eddie
Stephen Smith
on Apr 13, 2012 at 3:19:04 pm
So you used the log and transfer window to bring the footage into FCP and it will no longer import into FCP?
Stephen Smith
Eddie Aldridge
on Apr 13, 2012 at 3:25:27 pm
Yes, thats correct. I can see the files, but they are all grey and I cant click on them.
Eddie
Stephen Smith
on Apr 13, 2012 at 3:29:39 pm
Can you open the .mov files in Quicktime?
Stephen Smith
Eddie Aldridge
on Apr 13, 2012 at 3:34:44 pm
HI,
Mov is OK.
The files I am trying to import has a .mts extension
Eddie
Eddie Aldridge
on Apr 13, 2012 at 3:37:11 pm
If I browse to the directory via finder, I can access the files.
If I try and get to the files from the import utility in FCP, they are grey'd out.
Eddie
Stephen Smith
on Apr 13, 2012 at 3:42:31 pm
To import a .MTS file into the Log and Transfer window the file must remain in its original file structure. Meaning, when you are ready to get the files off the card you must bring everything on the card over and not re-arange things. All of those files that come with it that look like junk tell FCP what the clips are. I think you need to check out this tutorial by Shane Ross: http://library.creativecow.net/articles/ross_shane/p2_workflow.php
Stephen Smith
