Log and Transfer window on FCP
paola laverde
on Apr 4, 2012 at 10:55:35 pm
Hello,
Re: FCP 7... My issue is that only the top half of the Log and Transfer window shows up. The bottom portion where you can drag your clip to transfer it to the browser window doesn't show up nor does the other side when you can log or take notes on the clip. It used to not be a problem before, now I can't see if the clip is being down loaded or not. Any insight will be throughly appreciated. Thanks!
