Compressor target size BUG
Cristobal Tapia de Veer
on Mar 29, 2012 at 2:54:59 am
Hi, I'm having a problem with Compressor: changes made in Inspector to alter the target size (changing bit rate) doesn't work anymore, meaning the size of the exported file stays the same no matter what I do... Now the first time I tried that it did work, changes in bit rate did affect the final size, but after that first (lucky :)) time it stopped working.
Someone ever had this problem?? any ideas??
thanks!!!
Jeff Greenberg
Re: Compressor target size BUG
on Mar 29, 2012 at 12:21:24 pm
[Cristobal Tapia de Veer] "changes made in Inspector to alter the target size (changing bit rate) doesn't work anymore"
Which codec? Some codecs (such as DV, ProRes) don't permit bitrate changes.
Best,
Jeff I. Greenberg
Editor/Author/Speaker/Consulting
My NAB seminar schedule, contact info and more
