Pro Res 422 Question
Mike Rasch
on Mar 27, 2012 at 4:42:46 pm
I just updated from FCP 5 to 7. So this is my first time dealing with Pro Res. I receive mostly mini dv tapes, but also digi beta, beta sp....I was wondering if the video I get has to be shot in HD to apply Pro Res 422 for exporting or if it even matters at all. Same question for the other Pro Res versions: Proxy, LT, HQ, 4444.
Daniel Sametz
Re: Pro Res 422 Question
on Mar 27, 2012 at 6:30:38 pm
Hi, Mike:
You can use Prores in SD without any problem.
I found that if your content is going to internet or maybe you are a student with a short film even some Panasonic cameras, like the AG-AF100, recomends Prores LT . Is just fine and it takes less disk space. Prores is the standard and it ok, altought my guess is that in most cases LT is just what you need, I would recomend you to not use Prores HQ or 4444 unless you were planing on doing keying or extensive color correction.
Mike Rasch
on Mar 27, 2012 at 6:47:11 pm
Will the video quality be that much better? I mainly just take my edited video and put it to dvd. It seems like the video quality couldn't really get that much better, but I don't really know.
Daniel Sametz
on Mar 27, 2012 at 7:45:40 pm
I dont think you will notice a significant improve, just stick to Prores LT. You can make some test just to be sure.
Danny Young
on Apr 4, 2012 at 11:57:06 am
I defiantly agree with Daniel, ProRes LT is the go for you coming from MiniDV and SP (Digital Betacam might have a slight improvement using ProRes or ProRes(HQ) but you would be hard pressed to find anyone to see the difference). For some more info on the codec have a look here http://support.apple.com/kb/HT5151
