Final Cut Pro White Box in Viewer and Canvas
Megan Heck
on Mar 27, 2012 at 4:32:21 pm
Hello,
I am trying to install FCP 7 on my iMac. After I run the entire install I get a white box in the Viewer and Canvas window. The only time time I can see the correct image in the canvas is when I change the the canvas settings to anything other then black. For example, white, checkerboard 1, checkerboard 2.
Any thoughts?
Rafael Amador
Re: Final Cut Pro White Box in Viewer and Canvas
on Mar 27, 2012 at 4:42:20 pm
Probably you have the screens set to display "Alpha".
Check the "RGB" option.
rafael
http://www.nagavideo.com
Megan Heck
on Mar 27, 2012 at 4:43:25 pm
It was set to RGB. But I found a solution, not sure if it temporary. System Prefs > Displays > Color> changes millions to thousands, and then back to millions. It seemed to work, although I'm a bit flabbergasted.
