FW800 hub
Chris Ingalls
FW800 hub
on Feb 29, 2012 at 3:06:13 pm
I just added a fourth LaCie drive to my Mac, for all my Final Cut projects and their associated elements. Since there's only one FW800 input on the Mac (and I like the convenience of all the drives connected simultaneously), I'm considering getting one of these:
http://www.nitroav.com/store/nitroav-8-port-firewire-800-1394b-professional...
Has anyone used a hub like this, and if so, do you recommend it? I tried daisy-chaining the fourth LaCie drive to the third, and it FCP kept freezing up.
Chris
Edward Brosens
Re: FW800 hub
on Feb 29, 2012 at 9:28:40 pm
You could try to prevent drives from going into sleep mode in the Energy Saver preference pane in System Preferences.
Or try this software: http://www.macupdate.com/app/mac/31158/keep-drive-spinning
Daisy-chaining the fourth drive should not be a problem.
