Freeze frame artifacts
Leonard Frankford
on Feb 28, 2012 at 5:40:03 pm
I am making freeze frames for a project and when I drop the frame into the sequence, render and then playback, there is a blocky artifact on playback. When you pause the playhead it looks OK, but as soon as I play the clip I see blockiness and extra chroma on the highlights. I've even tried exporting where the playhead lands as a still image/png and bringing it back in, but I get the same results. Has anyone seen this before? Any ideas? Thanks.
Leonard
Leonard F.
Stephen Smith
Re: Freeze frame artifacts
on Feb 28, 2012 at 9:05:54 pm
Try de-interlacing the still grab and see if that works.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Leonard Frankford
on Feb 29, 2012 at 1:33:31 pm
How do I deinterlace? I don't see it under any of the video filters.
Leonard
Leonard F.
Leonard Frankford
on Feb 29, 2012 at 1:54:57 pm
I found the smart de-interlace. It didn't help.
Leonard F.
Leonard Frankford
on Feb 29, 2012 at 2:58:02 pm
The de-interlace didn't help but it turns out the problem was that FCP was using a Sorenson 3 compressor for the sequence (these were strange .mvp video files to begin with). When I switched over to the DV compressor and rendered, the stills were fine--didn't even need de-interlacing. Thanks.
Leonard
Leonard F.
