Flash effect in this video
Wiebe Wakker
on Feb 19, 2012 at 10:38:32 am
In this video
they use a effect where the screen flashes/flickers. How do they do that? You can see it at 3:28 and further.
Shane Ross
Re: Flash effect in this video
on Feb 20, 2012 at 7:01:46 pm
They cut to black for one frame, then the footage for a frame, back to black...for a few beats. Like a second. So it looks like it flickers.
Shane
Little Frog Post
Mark Suszko
on Feb 21, 2012 at 10:45:36 pm
There's also some color correction done to one or two flash-type frames, along with the black frames, and in some places, single-frame inserts of b-roll from other angles. It's really just cutting, nothing high tech.
If you want to do this several times, I would build it on a separate track and copy-paste it over various sections.
Richard Herd
on Feb 24, 2012 at 12:56:32 am
This is easy in 7, tough in FCPX, if anyone cares, here.
One trick I like is as follows: frames go: 1, 2, 3, 4, 5, 6.
Cut each frame, then rearrange as: 2, 1, 4, 3, 6, 5. Timing it to the music can add an interesting stuttering backwards-but-wait-it's-going-forwards trippy vibe thing.
