Correct exporting of a rendered video from Final Cut Express 4
Brandon Eastman
on Feb 17, 2012 at 2:27:48 pm
I just finished editing a video for class and would like to export . /The /files /I /worked /with /came /from /a /Flip /Cam /and /imported /into /FCE4 /as /follows: Frame /size /1280x720 /60fps /compressor /h.264 /44.1 /khz /audio /32 /bit /floating
How /do /I /export /properly /as /to /get /the best /picture /quality. /Do I /export /using /QT /conversion /and /match /the /settings /listed /above ? /Exporting /properly /always /seems /to /confuse /me /bc /the /quality /is /bad /when /ever /I /do /it. That /degradation /in /picture /just /messes /with /the /flow /of /the /video /and /becomes /distracting /to /me.
Thanks /for /the /help, /and /sorry /about /the /slashes, /my /keyboard /is /messed /up /and /deleting /each /slash /is /quite /time /consuming!
Rafael Amador
Re: Correct exporting of a rendered video from Final Cut Express 4
on Feb 17, 2012 at 5:27:02 pm
Hi Brandon,
The problem with FCE is that internally renders everything in the AIC codec which is not very good.
Not sure if you will get anything better exporting with QT Conversion.
Try it, and yes, matching the setting of the footage except the codec. Try with something better than the AIC (if available) and avoid H264 unless you are making a video for internet..
rafael
http://www.nagavideo.com
