Exporting HD sequence with pictures: pictures look bad after compressing
Lotte Haase
on Feb 15, 2012 at 3:28:56 pm
Hello,
I'm trying to export a 30 min HD sequence with pictures in it. When I export 1920 x1080 the pictures look ok, but the export files are too big. When compressing for DVD or Vimeo or exporting in lower quality the video looks still ok, but the pictures not. How can I avoid that?
The video is shot with Canon 5D. Editing with FCP 7, apple pro res, exporting to H.264.
Hope anyone can help,
Lotte
Rafael Amador
Re: Exporting HD sequence with pictures: pictures look bad after compressing
on Feb 19, 2012 at 12:32:34 pm
[Lotte Haase] "The video is shot with Canon 5D. Editing with FCP 7, apple pro res, exporting to H.264. "
First export to Prores, setting "Render in high precision".
Then convert that master to H264 (multipass, key-frames auto and the data rate you want)
rafael
http://www.nagavideo.com
Lotte Haase
on Feb 20, 2012 at 1:37:43 pm
Ok, thanks! I'll try that...
Lotte
Lotte Haase
on Feb 20, 2012 at 1:45:57 pm
Don't see though where you can select "Render in high precision". But I was already trying to export as Quicktime Movie and then compress through Compressor and that looks better..
Rafael Amador
on Feb 20, 2012 at 3:38:17 pm
[Lotte Haase] "Don't see though where you can select "Render in high precision"."
IN Sequence Setting > Video Processing.
rafael
Lotte Haase
on Feb 22, 2012 at 10:13:08 am
Ok, it's already on "render 10-bit material in high precision YUV'. Or should it be on "render all YUV material in high precision"?
Rafael Amador
on Feb 22, 2012 at 1:39:30 pm
Render ALL material. That way the pictures (8bRGB) are also converted and managed in 10bYUV.
rafael
Lotte Haase
on Feb 22, 2012 at 1:50:35 pm
Aah of course! I understand now, thank you so much! Would never have been able to figure that out myself.
Thanks!!!
