Dropped frame error
vineet das
Dropped frame error
on Feb 15, 2012 at 12:31:17 pm
When ever I play the timelife in fcp i am getting a error of frame dropped
What is drop frame error?
Why is happening?
What is the solution to it?
(Note : I have mixed clips in my project differing in formats & codecs)
Vineet
(Trying to Rise)
Rob Grauert
Re: Dropped frame error
on Feb 15, 2012 at 7:26:43 pm
It means FCP can't read the footage on your hard drive fast enough to play back the footage in real time without skipping frames. This is not damaging to your media, but can be annoying when you're trying to work.
A few basic things to keep in mind:
Your media should not live on you computer's system drive. Your footage (in fact, all media for your projects) should live on its own hard drive, but a RAID is ideal. Even a G-RAID is sufficient for compressed formats.
Change your RT settings to Unlimited if you have to.
It's good practice to match all your media and timeline settings. If you have to convert things in Compressor before editing, do it. And don't work with H.264 files. Convert them to ProRes
Rob Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com
vineet das
on Feb 16, 2012 at 10:46:12 am
Thanks for the reply Rob
I have set it to unlimited RT & the files are in apple pro res 422 & dv pal codec, all are mov files. All the media is in my internal hard drive (not on that where i have applications).
Except all of this sometimes i get the error of dropped frame.
Can you you tell me why it occurs in between sometimes?
Vineet
(Trying to Rise)
Rob Grauert
on Feb 16, 2012 at 1:22:44 pm
"All the media is in my internal hard drive"
Unless you're on a Mac Pro and you're media is on an extra internal drive, take your media OFF the internal drive. Your media should live on a hard drive or RAID dedicated to storing your media files.
"Can you you tell me why it occurs in between sometimes?"
Like I said, it happens when FCP can't read the files from your storage device fast enough to play back the footage in real time. Next time FCP gives you the warning, simply mark the checkbox that says "Do not warn again."
Rob Grauert, Jr.
vineet das
on Feb 16, 2012 at 4:18:19 pm
Thanks Rob
I will try it
Vineet
(Trying to Rise)
