Exporting from Final cut pro 7 to Betacam SP
rajiv bopearatchy
on Feb 15, 2012 at 12:14:43 pm
Hello Everyone,
I just bought an apple Imac and got Final cut pro 7 installed. I am new to both Apple and Final cut pro. Can some one please tell me after i've completed a project how can i transfer the project to a Betacam SP and what firewire cable should I use? Please help me out here.
Thank you in advance.
Raj
Chris Tompkins
Re: Exporting from Final cut pro 7 to Betacam SP
on Feb 15, 2012 at 6:26:33 pm
You need an i/o card to lay out to tape.
You are very limited in this area with an iMac.
You need Firwire to Analog i/o such as the outdated AJA IOLA
Also look @ Matrox products.
Chris Tompkins
Video Atlanta LLC
Dennis Leppell
on Feb 15, 2012 at 9:33:41 pm
If you pass the video signal thru a dv deck, you do not need to lay off with i/o device. The trick though is deck control. We use a usb to rs422 converter/keyspan to control our beta deck.
rajiv bopearatchy
on Feb 17, 2012 at 5:20:06 am
Thank you dennis. Appreciate your help Very much.
rajiv bopearatchy
on Feb 17, 2012 at 5:35:46 am
Thank you Chris. Good tip. i will look in to both of the options.
