? Use and Avid Raid drive for Final Cut Pro ?
Dan Billings
on Feb 8, 2012 at 8:11:44 pm
Anyone know if I could use my old Avid Raid to work in Final cut pro? The drive is VR-RTR320 (SCSI Ultra 320)and was used about 3 years ago before making the switch from Avid to Final Cut. Been just sitting on a shelf since then.
I would think you could simply use this like any external Raid, just wipe out any old Avid files and start fresh? SCSI is a little outdated but all I would need is a card for MacPro tower.
The real key would be making it work with a MacbookPro, but I don't see any converters that would turn the SCSI to firewire 800?
Shane Ross
Re: ? Use and Avid Raid drive for Final Cut Pro ?
on Feb 8, 2012 at 11:39:01 pm
If you can find a SCSI connector for your MacPro, it will work fine. Adapter for laptop? Nope... No firewire converters, no Express34 adapters.
Shane
Little Frog Post
Dan Billings
on Feb 8, 2012 at 11:52:30 pm
Thanks for the info Shane.
