Cloning External Hard Drive
<< PREVIOUS   •   FAQ   •   VIEW ALL   •   PRINT
Randolph Harrison
on May 12, 2014 at 4:01:30 pm
Hello All,
First, I would like to thank you in advance for any advice or suggestions.
I am going to be editing an indie film on Final Cut Pro 7. The problem is, I'm currently working in a third world country with almost no support for anything Mac-based. I have two pretty old Western Digital My Book Hard Drives... I will be using one for all of my footage for this film... but because they are old, and I can't get a hold of a new drive here, I feel that I need to have an exact clone of my work on the second drive, just in case. Is there any software which is cheap (or free), which I can update daily with my work. I want to be able to switch drives, in case of an emergency without losing anything.
Thank you again.
Randy Harrison
Macbook Pro 17", i5, 2.53ghz, 8 gigs ram
OSX 10.9.2
FCP 7
2 x WD My Book
Eric Strand
Re: Cloning External Hard Drive
on May 14, 2014 at 1:45:50 pm
You could use Terminal and RSync at the end of each day. Only copies over what has changed. I'm not any sort of heavy terminal user, I just learned through googling.
In terminal you type:
rsync -av --progress source drive destination drive
@ericstrand11
Randolph Harrison
on May 16, 2014 at 12:43:50 am
Thank you very much, I'll check into all of that.
Mark Suszko
on May 13, 2014 at 4:26:44 pm
Try Carbon Copy Cloner?
<< PREVIOUS   •   VIEW ALL   •   PRINT
