Major clip speed problems
Ben Sutherland
on Jan 31, 2012 at 6:42:15 am
Hey Team,
I'm currently editing a video together in which some of the clips need to be sped up. The problem is that each time I speed the clip up it begins to play through at the new speed but stops on one frame in the middle of the clip while the audio continues.
Sometimes it jumps back to the right frame near the end of the clip but most of the time the audio just plays through while the random frame stays as a still image.
I've tried everything I can think of to fix this problem but I haven't had any success.
It would be awesome if someone knows what's going on and can help!
Chris Tompkins
Re: Major clip speed problems
on Jan 31, 2012 at 6:05:28 pm
Sequence settings?
Did you fully render after applied speed change?
Chris Tompkins
Video Atlanta LLC
Ben Sutherland
on Feb 1, 2012 at 2:03:39 am
What would the sequence settings need to be on? They seem to be set to the standard settings.
Yes the clip fully renders with no problems but then does not play through properly.
